Script to click menu bar item of PureVPN to connect vpn
Trying to create a script that will connected/disconnect PureVPN. There doesn’t seem to be a command line client for MacOS, only one for linux. I’m attempting to click the PureVPN icon and the first item which is “Disconnect” or “Quick Connect” depending on if the vpn is connected. I can get the status of the vpn by using do shell script “ifconfig |grep ipsec0”. If it’s not connected I don’t get a response so it’s an easy true/false test. But automating the connection/disconnecting is not so easy.
tell application "System Events" to tell process "PureVPN" to click menu bar item 1 of menu bar 2"
This appears to click the PureVPN item, but I can’t seem to click, list or get any the 3 buttons within the icon. i.e The pureVPN icon briefly highlights, but won’t click disconnect.
Does anyone have any idea of what else I can try. Either with AppleScript or something else
Results of various attempts:
get every menu item of menu bar item 1 of menu bar 2 → {}
get every menu bar item of menu bar 2 → {menu bar item 1 of menu bar 2 of application process “PureVPN” of application “System Events”}
get menu bar item 1 of menu bar 2 → menu bar item 1 of menu bar 2 of application process “PureVPN” of application “System Events”
get menu bar item 2 of menu bar 2 → error “System Events got an error: Can’t get menu bar item 2 of menu bar 2 of process \“PureVPN\”. Invalid index.” number -1719 from menu bar item 2 of menu bar 2 of process “PureVPN”
get menu bar item “Disconnect” of menu bar 2 → error “System Events got an error: Can’t get menu bar item \“Disconnect\” of menu bar 2 of process \“PureVPN\”.” number -1728 from menu bar item “Disconnect” of menu bar 2 of process “PureVPN”
edit: Also just tried using Automator to record the action and the result shows that click menu item “Quick Connect” of menu 1 of menu bar 2 of application process “PureVPN” is the correct one, but throws an error if I try to run the script it comes up with.
I wrote a script to connect to my company VPN, unfortunately I won’t be on my computer this weekend. I’ll try to remember to post it when I’m back on Monday.
Thank you! I’d really appreciate it. I’m currently stumped on what else to try
This is the script I am using, note that I had to make some changes to remove my company settings. Forgive the formatting, I’m on my phone and don’t know how to format code.
— Global settings
property theVPN : “VNet-Name” — Name of VPN
property connectionAttempts : 20 — Number of seconds to attempt connecting to VPN
property ipAddress : “00.000.000.0” — IP address
property serverPath : “smb://path-to-server” — Path to server to connect to
property serverName : “name-of-file-share” — Name of server to connect to
— connect directly to VPN
try
            do shell script “scutil —nc start “ & theVPN
on error errmsg number errnum
            display dialog “The ‘” & theVPN & “ VPN isn’t set up correctly.” buttons {“Ok”} default button “Ok”
            return
end try
— Wait for connection to be established
set isConnected to my checkConnection()
if (not isConnected) then
            repeat connectionAttempts times
                            —  pause here
                            delay 1
                            if (isConnected) then
                                            exit repeat
                            end if
            end repeat
end if
— If VPN is connected, then connect to cloud server
            try
                            do shell script “open “ & serverPath & “@“ & ipAddress & “/“ & serverName
                            display dialog “An error occurred connecting to the Cloud Server: ERROR “ & errnum & “ (“ & errmsg & “)” buttons {“Ok”} default button “Ok”
            end try
else
            display dialog “Couldn’t connect to VPN server.”
end if
— Verify connected to VPN
on checkConnection()
            set result to null
            try
                            set result to do shell script “scutil —nc list | grep -i “ & quoted form of theVPN & “| grep -i ‘(Connected)’”
                            set result to null
            end try
            return (result is not null)
end checkConnection
Thank you for sharing that. I’ll try it out when I get home tomorrow
