We have anyconnect setup and i want to test and eventually enable sbl. However i try to follow the directions to enable it via the xml on the local machine. I don’t know if im editing the correct xml file the correct way. Do i need to edit the xsd files at all?
C:\Users"user"\AppData\Local\Cisco\Cisco AnyConnect Secure Mobility Client\preferences.xml
SBL is controlled by the following file:
C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client\Profile\AnyConnectProfile.xml
You don’t, however, want to edit it directly. Use the AnyConnect Profile Editor tool to do so, which you can download from Cisco. The VPN Profile Editor will be the one you want to use once you have it installed.
You don’t need to edit the xsd files.
This link might be handy.
