Im planning to go to china soon for 3 Months and am wondering, if I could continue to work remotely, without my employer noticing, if I use a smart vpn-set up.
Does anyone have experience with that? I am not very technically skilled, so any recommendations would help!
If not then you will need to learn it. If no time to learn then use a paid vpn service but I don’t believe they work "well’ despite what people are saying.
Suggestion - don’t bother if no time to learn, things will always break first time.
Yes, you can do it. I’ve done digital nomad stints in China since 2015.
You’ll need a strong VPN setup with a couple of layers of redundancy in case one of them goes down.
It helps if your work is quite flexible and you aren’t on a lot of real-time calls and screen shares. The only year where it got stressful for me was 2023, when I was on a contract with a lot of high pressure and on-call availability. I basically didn’t leave my hotel for days at a time which sucked. All other years the lifestyle has been awesome.
I spent years running my own boxes which gets very complicated, but in the last couple of years I just rented a few commercial v2ray lines for my trips including that 2023 mega project as I found some very reliable HK and London connections which seem to have good peering. If you need a provider’s name, DM me.
Calculate your risks - there’s always a possibility that you’ll be caught. Your knowledge and experiences will reduce your risks but you’ll never be 100% sure.
Doing it right now, it’s fine but occasionally a little heartburn-inducing.
Assuming a few things:
there’s not a risk of you being sued or going to jail for covertly working remote in ML China and the worst that can happen is getting fired.
your employer doesn’t have a crazy level of employee surveillance. If your employer issues you a managed laptop and really wants to find your location they absolutely can. Most IT departments don’t actually care that much.
You have a legal means of being here and have researched the tax implications
Head to r/digitalnomad and check out their setups. I use a commercial VPN (astrill with private IP) and a self-hosted one as backup. Personally wouldn’t do this outside a tier one city with screaming fast internet. A lot of people you meet in co-working spaces are doing this even if they don’t openly admit it.
I did have a stressful period during the two meetings last year when every VPN connection kept going haywire.
What do you use to connect to your employers intranet? Do they have a vpn, if so what protocol? Do you use a company issued laptop? Mac, windows or Linux?
In general You could setup a ss proxy at your home network, configure your traffic to route through that.
if you’re not very technically skilled then it would be difficult to set that up, and will need to use paid apps that have features to make it easier for the layman (e.g surge). Otherwise use ChatGPT to help create a guide custom for your situation.
Heard letsvpn is working based on comments in other /r. Last year Astril seem to be the one but appears to have gone downhill. Would be interested on speed tests.
I’m getting around 200mbit via a LA VPS via a CN2 GIA link. It’s good for the price.
