Remote desktop options for Mac?
I have an Apple Remote Desktop license for myself for supporting users. I inherited it. It’s only for IT though as far as I’m aware. I’m not sure that could even be safely shared with a regular user.
On the regular, non-admin, supported by me for IT user side, what options are available for that mac user using remote desktop? In this case, we can say they have a mac at work and a mac at home, all owned and managed by organization. They also have a macbook. The user wants to be able to use some kind of remote desktop software on the macbook to connect to that work mac at home and the work mac at work. They would only be using one stationary mac at a time though I believe.
For their schedule I believe it’s possible for them to sign in at one location either that morning (say signing in on the home mac desktop) and then traveling (to work, but still wanting remote desktop access back to the mac at home). Yep, I know. But that’s what they requested.
I mention the traveling part because my organization does have VPN. It would be possible for the user to put one mac desktop at home on VPN in the morning or the work mac desktop on VPN at the end of one day. The VPN connection will last long enough for them to connect, at least the one day. That would be a scenario where they also put their macbook on VPN, and then all their macs are on the same VPN subnet, at least for a while. It sounds like a pain to do, but that’s an option if they really want this.
In general, what options are there for remote desktop from mac to mac like that?
And are any free? I’m really doubting that.
Is any version of VNC safe to use? The last I heard it wasn’t safe, at least for any free version.
Would Chrome Remote Desktop work on a mac? I have seen that work well enough on Windows machines. If the organization doesn’t want to spend money but the user still wants the option, then free would have to work, even when it’s a little bit of a hassle.
Open System Preferences to turn on “Screen Sharing” which will allow a remote user to connect. This would need to be done on both Macs. Connect them both too VPN. Take note of the IP addresses of each over the VPN connection or at least the IP of the one that’s not on the work network.
Then use the Screen Sharing app (built in VNC software, just do a spotlight search for it) to remote connect to whatever IP address you wish.
Other remote options work too but this one wouldn’t necessarily require a user on both ends to allow the connection. Good luck.
Chrome Remote Desktop is insane.
I have it running on 20 systems for 20 remote users and it’s been bullet proof for almost 18 months. I have all the local systems set to “auto log in” so that they on a boot they log themselves in and automatically get Chrome Remote running. In all 18 moths the only issues I have run into (outside of the occasional physical failure) have been maybe twice when google suddenly decided that everyone needed to reinter the passwords on the local systems, so that was a bit of a pain especially as it Google randomly logged people out over a period of a week - I assume it’s because I have “auto-update chrome” turned on. I should probably not have left it set this way. Also turn off “auto update” of course on all the systems as sometimes Apple requires the iCloud passwords to be entered on reboot. Easy to do if you have local access, but can’t be done or skipped remotely.
I have a separate single google account set up on all the IT / server / whatever, systems. That way I can easily log into those systems as well from one account.
And I have my own local system running Chrome Remote, and from there I run Apple Remote Desktop and do more detailed maintenance on all the local systems that way as well.
Aside from the 1 time a month that something weird mechanical fails, I could honestly maintain these systems from anywhere in the world.
BTW - one bonus but of advice. If the users are always remote, strip all external devices from the local systems. Remove all mice, keyboards, external monitors, usb hubs, printers, everything. 50% of my issues came from these things. I also had some systems booting off external SSD’s for speed, but I put them back on internal drives because internal stability was better than external speed.
Chrome Remote Desktop works fine on Macs
IF you are on Big Sur then there are new screen sharing hurdles.
Essentially the End User who wants to remote into the Mac, must have already logged in and checked the Screen Share box on that Mac physically. You can go around Admin rights but it’s a new thing.
Here’s something from Splashtop, one of the better remote services out there.
https://support-splashtopbusiness.splashtop.com/hc/en-us/articles/360035055131-MacOS-10-15-Catalina-11-Big-Sur-additional-Security-and-Privacy-requirements-for-Mac-Streamer-and-Mac-Business-App
Screen Sharing is built-in, based on VNC, and there are mobile clients available like Jump. Depending on your network you may need to tunnel it through SSH.
If your company already has it there is TeamViewer. Where I work we use it for both Mac and Windows (my daily machine for work is an M1 Air in a predominantly Windows environment). It works well after being granted the requisite permissions on the client(s).
We also trialled Bomgar with success on both platforms.
(I also have an Apple Remote Desktop license which works very well)
Obviously both come with a cost, but are not necessarily tied to being on VPN.
I agree with homeup. Give the desktops a static IP, turn on screen sharing (and allow the users access to the remote computer), and finally give remote users VPN access. Have them connect to their desktop using that new static IP (via Screen Sharing app.) They can save the connection as a file, giving them 1-click access to their workstations.
I use Zoho Assist that can be used for remote access even when users are not active on the destination machines. Browser based on the support end, and the app is easily installed on the user end.
Remote Desktop Manager (free edition) supports the Apple Remote Desktop protocol. So you can connect the same way you would using the paid Apple Remote Desktop app or Screen Sharing, even from Windows or Linux. As long as you VPN to the same network, it handles sharing the same screen or fast user switching seamlessly. Great for having a list of machines you connect to, you can have saved user credentials and apply them to all computers on a list as well, making it so you don’t need to re-enter them for each computer you add.
DWService will beat anything mentioned aside from ARD.
Edit:
Zoho assist comes pretty close, has ITIL features. But wit the tool set DWService is still the best.
While VNC is convenient, it is totally unencrypted. Using it over VPN does add some degree of security, but not a best practice. I really like Jump, they do support VNC but have their own protocol (Fluid) that is secure and much better latency. They have paid clients and a Team feature for uses like you outline.
Screen sharing or some equivalant config using remote management
It works OK. MS Remote Desktop is still light years ahead of anything in macOS right now though.
Lightweight, functional, always connected, free and for Mac? I think you’re looking for Supremo Control. I have been able to make my remote connections, even with VPN, with no problems.
Remote desktop software for Mac is becoming more crucial for businesses using Mac computers and laptops. As remote work becomes more prevalent, IT administrators and organizations require a secure way to access and fix problems, handle urgent tasks, and monitor the status of remote workstations. To facilitate collaboration from afar, the software needs to provide smooth remote connections across different operating systems. Finding software that supports Mac remote access can be challenging, but with Remote Access Plus, you can securely and conveniently access Mac computers with just a simple click.
Explore more: Link
[Enjoy free trial for 30 days]
yeah honestly, i don’t think anything beats screensharing.
for our org we use screensharing for fac/staff machines as you will prompt the user to allow it unless you are the user logged in or no one is logged in. With Big Sur+, users are notified when you are looking at their screen. easily configurable and you can keep track of who has access.
ard is convenient b/c you don’t need to prompt and it’s a bit more invasive, but we don’t mind for shared lab spaces when we need to assist in a pinch.
as long as you have VPN access, i don’t think you need to spend the money.
You’re absolutely insane if you don’t let Chrome auto update.
The day I discovered Chrome Remote Desktop to replace teamviewer for my personal use was the best day ever.
I’ll second chrome remote desktop. The only way to get better is to spend some real money.
If you are using teamviewer on a one to one basis you can use it for free. But read the TOS just to be sure. I also use AnyDesk and it works great. Of course both need access permission from the system
