Hey everyone!
I’m quite new to this space and was wondering if anyone here could give me some guidance/insight on their full proof Synology system VPN setup.
My issue currently is that I went with NordVPN but found out after that seeding was not really an option.
I’ve also had a few random connection errors which resulted in me having to reconnect everything.
What VPN do you guys use to insure you are safe from the eyes of your ISP and other outside eyes?
How do you seed your torrents?
I’d appreciate any assistance I can get.
Apologies in advance if anything wasn’t clear!
Using docker, deluge + gluetun for custom vpn setup. Went with this route to allow me to route other containers to the gluetun vpn container when needed. Setup proxy with gluetun too.
I set up a system where my family can request movies/shows and it auto downloads so a lot of torrents get submitted into deluge more than usual.
I’m mostly trying to avoid getting flagged by my ISP.
Would you say a seedbox would help with that over a VPN?
I’ve read up on it but a lot of people said it serves two seperate purposes so I got a little confused by it.
Good to know, I wasn’t aware of the possibility of VPN rules for private trackers.
I’m in a few but usually raw dogged my torrents and never went the VPN route on my PC.
Either approach should be sufficient to prevent your ISP from identifying exactly what you are downloading and uploading if done correctly, but using a VPN your ISP will still see the traffic for uploads/seeding which may or may not be a concern for you.
I personally prefer a seedbox because of the better upload speeds over my ISP connection and the uptime.
I used a number of different guides, mixed them all together and put them in a docker compose ‘stack’ tweeked for my needs using Portainer to run it. If you’re in the mood I can try to walk you through my docker compose. DM me if you’d like to give it a try.
I’ve been using TorGuard for about 3 years after my ISP flagged me. Originally I was using the normal Deluge client with SOCKS5 proxy setup to TorGuard. It worked quite well. When I got my NAS about 18 months ago I decided to setup the whole Arr suite and chose DelugeVPN as I liked the client. Now I maintain good ratios on 3 different trackers.
