I have managed to remove EVERYTHING apart from this engine service (the AV, the VPN), HOW CAN I DELETE IT PERMANENTLY??
I cannot stop the service, I cannot use pskill, I cannot use external software, the methods I used before does not work on this one, is there possibly some way where I can boot windows without booting anything except necessary so then I can delete it? I made the mistake of not reading when downloading something through Linkvertise and this process won’t end, it won’t stop, and the uninstaller always sticks at 85%; it has more permissions than me and I’m the only user on the PC, I AM the highest priority, this is the one issue that INFURIATES me.
No, I’m not willing to do a factory reset, I have way too much data that I cannot just transfer.
You can see my very hostile rage in this picture
Try booting in safe mode.
Next time, don’t download shitty antivirus software
Surely your important data is backed up somewhere so if the drive fails it’s easily recoverable. Every PC owner knows to do this right?
Delete it thru control panel
this made me realise that i can fac reset without deletion of files. but that also means that my 80gb of car mods will be deleted and so will a lot of my everything
bloatware, i didnt want it i mindlessly clicked through an installer. i already have an AV
my last system restore point prob still has rav on it
that leads you onto the window in the picture
System restore is not a backup, especially not if it’s on the same drive as your OS. If that drive dies, bye bye everything.
You should have your important data backed up on another drive, and a second backup on the cloud.
you have given me the idea to finally buy a sata cable for the 1tb hdd sitting in my pc
hopefully my ssd doesnt die any time soon
Use something like syncbackfree to copy your data on a schedule (mine does it daily). Once you’ve got all your important stuff backed up, do a full windows reinstall.
I’m seriously shocked whenever people say they’ve got important data, and when pushed you find out they’ve not got a single back up of it anywhere. What did you think would happen if your drive failed?
thank you very much. i mean its not ACTUALLY important data its more “things on my pc i would not be bothered to redownload because theres so much of it” or some things of small sentimental value.
