Does the proton unlimited subscription also include proton pass?
It includes everything so yes
Yes, it includes all Proton services.
Everything about their Proton Plans.
So, not everything is included. Proton Pass is.
Does the VPN also apply to all apps on your device (e.g. X and telegram)?
From your link: “Proton Unlimited is our great value bundle that gives you all our services in one easy subscription”
Yes, unless your exclude them by split tunnelling if it’s available.
Yep, Proton VPN is per device (10 devices for Unlimited, but in some cases your router can be a device). So everything connects through the VPN. On some platforms you can configure split tunnelling to exclude apps from using the VPN.
Take your time to explore the possibilities for the platforms you will be using.
No Wallet. No AI. So not al services.
It gives all services but not all features in those
Scribe isn’t a service / product, it’s an addon to an existing service.
Wallet is still beta / early access. I am sure down the line it will be included in Unlimited too. There are so many invites around that it isn’t really hard to get in either.
