A few months ago, two of the podcasts that I listen to on a daily basis would not download when I have ProtonVPN turned on. I have experienced this with two different podcast apps (Overcast and Apple Podcasts). The two podcasts are Everything Everywhere Daily and WSJ What’s News.
I’m wondering if this is part of the ads that are imbedded with these podcasts that either block known VPNs or it might be a conflict with ProtonVPN ad blocking.
Has anyone else experienced this issue and is there a fix or workaround?
Same issue as others reported using Downcast on IOS. Only solution is to take down the net shield … Proton team any way you can fool them so we can keep blocking trackers and listen to podcasts???
Hi I also having issues with downloading over apple podcast on sonoma 14.5 I tried with block malware only did not work, then I tried with block ads and trackers did not either at last netshield off but did not work as well. I use US FL74 server but I also tried in secure core did not work.
It is working well now. I’m not sure if something changed in an update, but I am able to download all of my podcasts with the “Block malware, ads and trackers” turned on. Thank you for your great work and the good product.
I’m having issues with a few different podcasts using Pocket Cast, specifically downloading Wondery the Big Flop. On the US GA#21 (not sure if its just this server) seems to be an issuse for many podcasts via Pocketcast.
i have the block malware, ads, and trackers option selected.
