Please help, how to fix?
Hello i got a new computet yesterday, havent used pvz much on computer, these ping are making it unplayable, what am i to do? Thanks
Bro lives on the ISS
Do u have a vpn on or something? Idk why this would be happening otherwise
can you tell us about your new computer?
are you using a desktop?
a laptop?
if desktop, a USB wifi adapter?
where did you put the adapter?
ethernet?
bro lives in Antarctica
Ill check abouy the vpn
I turned mcafee vpn on and it helped? I dobt get it, the vpn put me in “fastest location” which is just my country idk what its doing
Hi itd a laptop hp i ahvr a wifi extension right outsidr my door
I also don’t know why it helped. Maybe because it said I were in a different location than u actually we’re and it might have been interfering with your internet connection
Yeah thats what im thinking, thanks for the helpф
А у тебя впн какую страну показывал? А то тоже много где подвисает.
I manage to fix it now! I didnt have my location enabled and so my comouter didnt know where i was. :blush:
