Playing Netflix with VPN Unlimited
I had bought a lifetime membership for VPN Unlimited some time ago, so I decided to download it to my iPhone. I’m choosing the Netflix setting on the app, it connects to the US server, and Netflix loads all US titles. However, when I try to play a show, it says something like “this title is not available at the moment”. I live in Turkey and Netflix is shit here. Since I already paid for VPN Unlimited, I would love to utilize it. Any solutions?
Update:
I tried Plexvpn to watch Netflix and it works through LA CN21, all locations of HongKong, Taiwan, Franch and Germany.
Maybe you need to change the channel. I used plexvpn and in this app only certain channels work when I choose the Netflix.
You may switch servers to connect and have a try.
Try switching cities. I have a vpn and I set it to United States, New York or Los Angeles.
I travel a lot and also use VPN Unlimited to watch Netflix
I’ve never had such a problem :((
I can suggest to contact their customer support , I think they’ll help you :slight_smile:
I had IPVanish and it only worked it some American cities, like New York, Los Angeles, Salt Lake City And Dallas. When I tried the others. They didn’t work
Yes if you use the Netflix or Hulu setting, it should work fine. I also use a Smart Dns for good measure.
May be Your vpn not supports netflix try to change a vpn service and refund your current service try to visit Cnet.com ,Rivipedia.com & Pcmag.com get what vpn works on netflix whats not
So wait, I’ll ask them to change my IP address? is that possible?
I’ll definitely try that, thanks :slight_smile:
