I’m moving to Abu Dhabi next week and would like to know which paid VPN works best for WhatsApp calling. I’m considering Nord and Surfshark; do you have any recommendations? Should I avoid using Etisalat?
Express VPN. Been using it for 10 years without issue.
UrbanVPN is free and works , or ProtonVPN (paid).
Why paid ? Your can also use vpnify
Always used Nord and Proton. Both are pretty good and works well here without interruption
Nord’s “dedicated” vpn server
been using Private Internet Access for just about two years, never had an issue with it
Paid vpn works only on home broadband or WiFi. It won’t work on mobile internet. Proton VPN is excellent
MegaVpn is like 2 dirhams a month
Use wireguard protocol using free available configurations,i can send you the link if you need
Found this resource, might help.
Using Surfshark, and working great. Good speed. You can get 3month trial. PM me if needed I’ll guide
I heard it’s going to be illegal soon and can potentially attract hefty fines. Is that true?
ProtonVPN has worked perfectly for me since the last 2 years
I have been using surfshark and its been working fine for me for around 5 years now
Isn’t there a new fine on VPN? I’ve been seeing it over the tiktok everyday
PIA for the last 8 years has worked a treat. The other one I have is smartdnsproxy for getting streams from back home. It’s cheap and comes with a VPN good enough for WhatsApp calling.
SurfShark. I’ve used it for 4 years and the speed are pretty solid.
protonvpn (free) works just fine for vpn, its the best stable and secure vpn you could find, feel free to upgrade for lower latency servers
Proton and mullvad cheap asf
