After updating to 12.7 and windows to 24H2, all the connections but WireGuard are failing to connect or even failing to give me a failed connection screen. It just stops connecting!
I checked Network Connections in Control Panel and saw more than 10 channels (Open VPN Data Channel Offload#XX) and they just get created each time I connect via UDP(you can delete from Device Manager).
The issue is not present in 11.11. If your having a similar issue, you can switch to this version.
