Working with a vendor that has built Windows and RedHat VMs in a NSX environment. These VMs communicate across an IPSec tunnel to a VPN concentrator which then has connections to remote offices that have IPsec tunnels to the concentrator. VMs can SSH between each other but not to the endpoints immediately off the concentrator or to endpoints at the remote offices. VMs can ping and HTTP/HTTPs communicate to everything however.
Have reproduced the VPN infrastructure in GNS3 and can SSH everywhere. Also reproduced IRL without the NSX environment and can physically SSH everywhere as well.
A port scan from a endpoint back towards the VMs says the port is filtered. Vendor seems alittle perplexed on why SSH is broke but everything else works. Anyone seen similar behavior through an NSX hosted VM and found some obscure setting?
To work it out I’d need more info.
What gateway/DFW firewall rules are in place? Is there a default deny at either level?
Are the endpoints defined in an IPSet as part of any firewall rules?
What logical routing/topology is configured within NSX?
It could be a mtu issue between the endpoints creating vpn.
Try ping with no defrag to test it
You probably have an isp in the path of your vpn tunnel with a 1450
I know nsx-t vpn has some pmtu setting you can enable
This is nsx-t?
If so, reduce the mtu at vpn level. You can do this with tcp mss clamping config.
Try something silly like 1300 mtu and test for a few days.
If the issue still happening, you need to pcap it from VPN interface and see what is happening between endpoints.
ISP may be messin there
All great questions I wish I had the answers to. I’ll see if these questions flush anything out with the vendor.
Thanks for that. We’ll give it a try.
nping --df -mtu 1496 passes from vpn endpoint to Linux host in NSX environment. 5 sent / 5 received.
