NordVPN keeps draining cellular Data while connected to WiFi on Pixel 9 Pro fold
Hi, I’ve noticed this problem since yesterday,I received a 10GB limit reached warning, to be sure I’ve adjusted this warning to 11GB to monitor usage, woke up it has used another 2GB at night!
Ive been trying to figure out how to reproduce the problem, I’ve noticed that streaming with Meshnet & NordLynx protocol enabled, It uses data (While WIFI connection is on). When manually setting protocol to OpenVPN, Problem stopped, I could not reproduce the problem anymore. even after switching back meshnet on, Problem solved right?
No, this morning i received warning has been breached by a whopping 2GB! I am pulling my hair at this point. (App data usage shows NordVPN)
Ive set a new warning and also, cellular data limit , dataplan used for over 70% for this (bug).
Pixel does not have an option to not use cellular while connected to WIFI setting, that would be a perfect work-around.
Some related post; https://www.reddit.com/r/nordvpn/comments/yuuzw5/nordvpn_using_cellular_data_even_on_wifi/https://www.reddit.com/r/GooglePixel/comments/180pwe3/turn_off_adaptive_connectivity_if_youre_phone/
PS, NordVPN does not have a submit a ticket section. I would have made a ticket ofcourse for this issue.
Information / stuff I tried on my phone:
My Phone Pixel 9 pro fold, Android 15 , Nord VPN app version 8.0.2
  • Settings > Network & Internet > Internet > 5G > Apps data usage > NordVPN ( I have disabled option ’ background data’ )
  • Meshnet On
  • NordLynx protocol Turned off/on
  • Wifi adaptive connectivity (disabled)
  • Resetted network settings
  • At this moment I am unable to reproduce the data usage…
Many phones will report high data usage on vpn apps even if something else is using the data - because it has to go through the vpn, I would recommend to try disabling nord and see if data usage is still absurd - then you can see if any other app is causing the issues
After almost 24h, It did not use cellular data, this is nice! but also scary, since spreaded across a week my phone swallowed up 14GB while connected on WIFI, for now i have set a hard limit on cellular data combined with a warning.
Update, went outside and back to wifi at home, using reddit it is draining again while connected to WiFI seems VPN connection is not switching usage from data and WIFI?
I think I found a setting on Pixel : phone is connected to Wi-Fi at home: enable Developer options by tapping seven time on Build number in Settings > About phone, then disable Settings > System > Developer options > Mobile data always active.
This might be the cuplrit, seems to be working strange after an update will post if this helped.
Ok unfortunately that was not the case, you can disable background data on NordVPN itself, but even with all of the above it keeps happening. I think I have it now, it seems it’s not a NordVPN problem but a pixel problem on android 15. There is no disable data widget, and you have to disable data on the background option on every single app, this does not mean the app won’t work on cellular when That’s only available. Damn, been a ride I hope I got it.
Thank you for the reply, it seems to be native issue on the pixel phone (android), since Nord still encrypted the data usage, does not mean it is causing it. I think this is an Android problem. Thank you for the reply, perhaps many pixel users don’t use Nord since pixel comes with Google vpn.
The encryption overhead should be up to 20% on average - that means something is still causing major usage
