NoLag Vpn warzone question
Hey guys, living on west coast and recently tried using no lag vpn. It was good for getting easier lobbies at first but seems to be losing its effectiveness. Anybody have any locations they are connecting to and having good luck with? I’m a 1.1 kd but only have time to play an hour or 2 a night, so it’s tough running in the sweaty 1.2 kd lobbies night in and night out all the time.
Before you scold me, I support having a ranked matchmaking system for when I want to sweat and try hard. With that said, I work full time and can’t play 8 hours a day…I’m 30 years old and just want to kick back, have a cold beer, and play some games in a laid back lobby.
Thanks in advance!
Unlike the comments saying it doesn’t nolag does work. The way it works is it makes it take longer to get into lobbies so it prioritizes connection over SBMM. That does not mean you’ll get bot lobbies every time. Sometimes you just sneak into a sweat lobbies especially with more people playing at night. Nord and true VPNs make you lag
Hey, to the best of my knowledge, nolag doesn’t really work, it’s not a real VPN.
Check this out instead: Warzone VPN Guide: How to Get Bot Lobbies in Warzone!
The best location for the us is singapore. My pr before noloagvpn was a 17 now its a 32.
Kd before nolagvpn 1.7 after nolagvpn 3.6. Everyone that says it doesnt work hasnt updated their configurations or isnt using a location that is currently online.
Can you play nolagvpn with friends and still get bot lobbys? (I have nolag and my friend doesnt, do we still get bot lobbies if we que?)
Thanks for the link. Maybe I’ll try nord vpn? Have you had any luck with those?
Cheers
Just got nolagvpn and I was curious how you update the configuration files? Do you just download them again?
how often do I have to update my configurations?
You still using Singapore ?
I can confirm both Nord and Cyberghost work, tried them both.
Hey Sley, work as in getting easier lobbies, or just as vpns in general? Thanks for the reply!
What server you connecting to on nord vpn? I’m trying Brazil and it’s pretty laggy
Any potential servers that are good enough? I’m looking to set ExpressVPN for Xbox. I live in India and I’m looking forward to get some servers that are good enough
