No tray icon after connected to VPN
After connected to the same VPN (Cisco), my new laptop didn’t show the “tray icon” as in my old laptop did (both Windows 11). I have tried Network Reset from Settings. However, it only restarted and still automatically connected to the wifi. It didn’t seem to “forget” any network settings. Any idea how to fix the missing “tray icon” after connected to VPN?
Hi u/LogicalAtmosphere521, thanks for posting to r/WindowsHelp! Don’t worry, your post has not been removed. To let us help you better, try to include as much of the following information as possible! Posts with insufficient details might be removed at the moderator’s discretion.
  • Model of your computer - For example: “HP Spectre X360 14-EA0023DX”
  • Your Windows and device specifications - You can find them by going to go to Settings > “System” > “About”
  • What troubleshooting steps you have performed - Even sharing little things you tried (like rebooting) can help us find a better solution!
  • Any error messages you have encountered - Those long error codes are not gibberish to us!
  • Any screenshots or logs of the issue - You can upload screenshots other useful information in your post or comment, and use Pastebin for text (such as logs). You can learn how to take screenshots here.
All posts must be help/support related. If everything is working without issue, then this probably is not the subreddit for you, so you should also post on a discussion focused subreddit like /r/Windows.
^this is the “tray icon” I meant, the new laptop still shows normal wifi icon after connected to VPN
Did you find any fix for it? I used mullvad vpn which always showed up like this but after I turned it Proton it won’t change to this. I’m jsing windows 10
