Original post - https://www.reddit.com/r/vpnreviews/comments/9v2j0c/namecheap_vpn_fine_on_ios_bad_on_windows_10/
I thought it would be fair to make an update post, since some issues I mentioned in the original post have been addressed.
In regards to the iOS app, in my original post I said:
The in-app purchases price mark up is insane though - around 60% more expensive than on their website, so I’d recommend paying on their website if you do want to try them out.
While this is still true for me, it won’t be true for everyone. If you’re in the US, the markup will be 30%, because Apple slaps a 30% fee. I’m from the UK and the markup in app is around 60% because according to Namecheap:
We would like to explain that Apple sets the corresponding prices based on the USD price, and adjusts them periodically - and that’s why there may be a discrepancy.
Anyways, it’s not a huge issue, since you can sign up from the website and get the original low price.
In regards to the Windows 10 app, in my original post I said:
The performance on Windows 10 is very unstable - both download speed and ping seem fine, but sometimes it takes 5-15 seconds just to connect to a website. I’m guessing this some sort of a IKEv2 certificate issue (I don’t know enough about this). I contacted Namecheap support who recommended switching to OpenVPN, but after I explained that there’s no option to do that, they just said they’ll look into it.
Namecheap support kept trying various fixes and found that IPv6 being enabled on my network adapter was the issue. I disabled it and all of the performance issues I mentioned went away.
Yes, it’s still IKEv2 only and the app is still pretty basic (apparently it’s still in beta, even though the software version is 1.2 ), but at least it’s now very much usable with great performance at a relatively low price.
I ran some speed tests…
Not connected to VPN:
Ping 9ms - Download 92.22 Mbps - Upload 6.10 Mbps
Connected to Namecheap VPN (server in the same city):
Ping 14ms - Download 84.54 Mbps - Upload 5.66 Mbps
