Multi Site Network to Cloud Gateway Ultra
I manage a small 3 site Deployment of Unifi Gear.
I host the Network Manager on-site as a VM, which I control all 3 sites and use the automagic VPN features.
If I get a new Cloud Gateway Ultra on my primary site (where the network applicatoin is hosted) I understand I will not be able to adopt the new Gateway Ultra. However will I still be able to point my remote sites to my main site for management?
Additionally, I assume I will need to migrate all the on prem equitptment behind the Ultra to the new Network application hosted on it?
Hello! Thanks for posting on r/Ubiquiti!
Ubiquiti makes a great tool to help with figuring out where to place your access points and other network design questions located at:
If you see people spreading misinformation or violating the “don’t be an asshole” general rule, please report it!
UCG ultra can only manage 1 site. All sites can be viewed in the unifi cloud interface. Yes you will have to migrate all on premise equipment. This can be done 1 of 2 ways you can take a backup of just the single site and restore it to the UCGU Network Server or you can reset everything and start from scratch.
Thank you! Questino though, how do you backup just a single site?
I worded it weirdly but you back it up and when you do the restore you select which site you would like to restore. I would personally just take down the SSH credentials for each device reset everything and start from scratch though. Unless its a really complicated network.
