Mobile taking too long to download content
It has taken me over an hour to Download it (1.9 gb) and it has just reset at 65% what do I do?
Edit:it just keeps resetting
FOUND A SOLUTION!!!
This same problem happened to me as well for a couple of days.
You can download the game easily, what you should do is: BE PATIENT.
(I’m not sure about everyone’s case, but I did this so I am sharing, IT MIGHT NOT BE NECESSARY)
  • Download this app from Play Store : ADM
  • Open it and go to Settings > Downloading > Turn on Auto-Resume
  • Then just close the app, you might see its notification, leave it as it is, You can uninstall this app later.
NOW THE ACTUAL THING, BE PATIENT: Think of it as not 1.9GBs but something like 10-20GBs, it’ll take time surely.
  1. Open your Fall Guys Game, start the downloading.
  2. MINIMIZE THE GAME (keep it in the background apps, do not close it).
  3. Look out for the Notification from `Download Manager`, that is your main progress.
  4. This progress bar will disappear multiple times, but do not worry it’ll reappear again.
  5. Let the download going, NO MATTER WHAT: DO NOT OPEN THE GAME, this will reset the progress.
I think it happens that download manager loses connection for some reason, by default it tries again to resume the download, which we want. That isn’t the case if you open the game, the game resets the download progress after a few seconds of not progressing. We do not want that. So,
BE PATIENT AND DO NOT WORRY IF THE DOWNLOAD MANAGER NOTIFICATION DISAPPEARS, IT’LL NOTIFY WHEN THE DOWNLOAD IS COMPLETED. LET IT BE, DO NOT OPEN OR CLOSE THE GAME FROM THE TRAY.
Hope it works for you too! :smiley:
Easy fix. Just open fall guys to download it ofc, then close the app (don’t swipe it away) so it sits in the background. Let it download and just wait until the notifacation says its downloaded. Its weird i know but it worked for me🤷‍♂️
the best way to fix that (that worked for me a lot) is to do this steps, when fall guys start to download, check your notification, if you see the fallguys download, click on it(if doesnt work, then nothing), do not cancel, after it makes you go to the download page, you have to stay there untill fallguys is downloaded, if the download wont continue, do not panic, follow those steps, first of all, pause the download, and after resume, if you dont see the file downloading just simply go to the fall guys mobile app and like that it will continue the download, after just go to the notification again and do this loop untill fallguys is fully completed, i hope this helps, tbh it should fully helps (i want some thanks cuz i like to help peoples😊)
and even the download speed is too slow and its not about internet connection
It keeps reseting on my phone too. I tried to download it 5 times already.
yeah 4 hours of trying for me
Change the lock screen sleep setting into never sleep (just this once), and keep downloading. It’s slow, took me 30 minutes.
Mine was reset after 97 percent
Now i have no data anymore
Pwease gimme wifi🥲
same, its getting annoying
If someone had the same issue and solved it SOS i need ur help :sob:
Mine didn’t even across 0.00%and failed with code:5
Anyone facing this
I have the same issue…still can’t solve it
I’ve been Having that problem too even and I saw it right in front of my eyes just reset over and over again at 52.6% and it is not a storage problem cause I have 4 gigabytes free so yeah and my internet is definitely fine at full signal strength 5g wifi but by what I can tell it could be using ram to store the downloaded content before adding it to storage so yeah and if it really is done that way then that is just really dumb to store it like that [edit] while I was reading all this it apparently finished in the background so just keep it running in the background and it will finish downloading and won’t reset then check the notifications to see if it finished downloading
When you start downloading the additional content, leave the app and let it download in the background (don’t clear it from recent apps).
Monitor the progress from the notifications area. If it stops at some point, go back to the app.
Be there for about 2 secs and then leave again (do not stay there for too long, else it would start all over again)
Repeat this till you see “Download finished” at the notifications area. Return to the app.
This is how it worked for me.
My download won’t even start, any tips¿
Here’s what worked for me.
After reading some comments and trying different methods, here’s what worked.
Some of the steps might be unnecessary, but i can’t really tell.
(it didn’t work from the first time, i had to do it again, 2 or three time before it finally worked)
1- i made sure i had enough storage
2- someone in the comments said i should try vpn and connect to a US server, so i did, but i’m not sure if that helped or not.
3- i changed the lock screen sleep time so that it doesn’t turn off quickly.
4- i launched the game, and when it started downloading i clicked on the download bar from the notifications, that led me to the phone system download page, where i could monitor the download better, see how much time is left, see the download speed and pause/continue the download. (obviously don’t swipe the game away)
5- here comes the active part, where you gotta be patient,
every now and then the download would stop, i click on continue from the download page, then go to the game, then quickly back to the download page, and the download resumes, sometimes you have to do it twice.
6- i kept doing that whenever the download stopped, which was every other minute maybe.
sometimes only clicking on resume would work without going back to the game.
until the game was fully downloaded.
So here’s my trick to download the whole data in 5-10 mins with approx 4.5 - 5 Mbps
  1. Download any usa vpn(I will recommend Turbo vpn from playstore)
  2. Connect to Usa and then open fall guys mobile app, after trying to download the fall guys notification should say waiting for network.
  3. After that keep the fall guys app running in the background, turn off the vpn and return to the fall guys app running in the background.
  4. It should start downloading with the max internet speed you have(Mine was 4.5 - 5 Mbps) and it took approx 10 mins.
Hope this trick helps for you.
I been downloading for 3 hours and I’m at 30 percent
Just dont pause downloading thats it
