Hi
I travel soon and would need an Mobile Desktop Router who support that the Router them self can create an VPN Connection to my Router at Home so all Device connect can talk in the Lan also with the Server.
I found some Router from Zyxel but the dont support VPN…
It should cost <200€ with build in LTE and have ~4 Lan Ports for local use.
Thanks!
Look at the GL.iNet travel routers. I use a couple to connect from remote locations to my WireGuard home vpn.
If the router doesn’t have enough ports a simple unmanaged switch would help increase the number of wired clients.
Mikrotik has a few products that fit your requirements like the hAP ax lite LTE6 or Chateau LTE6.
I must reduce the weight as much as possible I even cheat by packing the heavy stuff into my Handluggage…
Thanks for replay. Do you use a Router from that Company?
