(Mobile) Can’t login on iOS with surfshark connected
Like it says, on vpn because I’m on the wifi at work and jagex doesnt like the ol vpn I guess. It will work on some servers (south korea but fk that) Anybody else have this issue and know a workaround?
Botters are notorious for using VPN services, so it is possible your VPN provider already has their IPs banned from Jagex servers. Just a guess though.
You can use cellular data. I believe it uses less than 10mb an hour
Have the vpn off click play and than swap to the vpn app and turn it on
[FIX] It appears to be Surfshark’s optional ‘clean web’ function that stops OSRS mobile from logging in (blocks ads, trackers and malware when VPN is connected).
Through my brief testing I have established you can connect to the VPN with ‘clean web’ turned off, log in to OSRS mobile and then quickly go back to the Surfshark app, turn ‘clean web’ back on and go back to the game without issue (not that you really benefit from it on OSRS mobile).
False they will almost never use a vpn they use something called a proxy :slight_smile:
No signal at work sadly and the work wifi blocks osrs :frowning:
Work wifi blocks it too :frowning: only works with vpn
They’re the same thing
I just tried it with expressVPN and it worked fine. Might wanna switch to that one.
Yeah but have the vpn off as you click play than turn it on of the reverse of that have it on as you click play and turn it off
Technically yes but in practice no
already paid for 2 1/2 years of surfshark :confused: ill just stop playin tbh. Thanks tho
