Mindustry online?
is there a way to host your campaign for a friend from another country to join?Like how one would do on lan?
Yes it is. Press escape and click host server. If you don’t have steam version of game use Hamachi to make LAN
On steam, you can just press host game and invite him into the game from steam. I don’t know about mobile, but I use Hamachi to play “Local Area Network” with my friends.
Yes but to join through IP you need VPN like Hamachi or Wireguard. You can also open ports on your router to connect directly but I wouldn’t recommend that
Opening a few select ports isn’t anything to worry about. especially if you have it toggled by the host running the game (you can set up something within the router or with a short script)
I tried himatchi but with my friends but it never quite worked as well as an open port
You can also use wireguard or radmin VPN. Personally I am not fan of opening ports because it is always threat
