Making Tailscale Devices Visible on Omada Controller's Client List
Howdy,
I’m trying to make my Tailscale devices visible on my LAN, specifically on VLAN 66, which I’m using for VPNs.
Here’s my setup:
  • Omada Network:
    • Router: TP-Link ER7206
    • Switch: TP-Link SG2210P
    • Controller: OC200
    • VLANs: Using multiple VLANs, including VLAN 66 for VPNs.
  • Tailscale:
    • Tailscale is running on a server that has access to VLAN 66.
    • I can access devices on VLAN 66 from my Tailscale network, and vice versa.
    • Exit Node is enabled on the server.
  • ISP: Starlink (behind CGNAT)
I want to see my Tailscale devices (that are connected to VLAN 66) on the main Omada controller’s client list. Currently, they are only visible within the Tailscale admin console.
Can I use IP aliases in Omada to achieve this? Would assigning an IP alias within the 10.0.66.x subnet to my Tailscale devices make them appear on the Omada client list?
If IP aliases aren’t the solution, are there any other ways to make Tailscale devices show up on the Omada controller’s client list for VLAN 66?
Thanks in advance for any help or suggestions!
you will never be able to see anything other than the talscale server in omada, if you want to see vpn clients in omada you must use one of the vpn services that run on omada
