Anyone else having issues with iMessage and other apple services working properly when connected to Warp VPN with the new Mac update. None of my notifications/messages will sync/send when connected but will instantly start working when disconnected. This only started happening after I updated to the new Mac OS version.
It’s also impacting my face times going through via iOS 18
I have the same issue with notifications and FaceTime giving me a hard time when using WARP with latest MacOS/iOS.
I’m having the same issues. Updated my phone to iOS 18 and my Mac to Sequoia and now my Messages will not sync to my Mac unless I turn WARP off.
I had the same issue but after reinstalling WARP it worked. Had to delete the app and install it again.
Adding *.apple.com to your split tunnel config should fix this.
Hey guys,
Just solved the issue configuring some of the IP addresses (I assume Apple ones) for exclusion in Split Tunnel settings.
Under Advanced → Split Tunnels, choose a mode:
Exclude IPs and domains — (Default) All traffic will be sent to Cloudflare Gateway except for the IPs and domains you specify.
You might exclude the entire 17.0.0.0/8 address block.
Or you might opt-out (my choice) to exclude narrower subnets:
IPv4:
- 17.249.0.0/16
- 17.252.0.0/16
- 17.57.144.0/22
- 17.188.128.0/18
- 17.188.20.0/23
IPv6:
- 2620:149:a44::/48
- 2403:300:a42::/48
- 2403:300:a51::/48
- 2a01:b740:a42::/48
More info here: https://discussions.apple.com/thread/255761213?sortBy=rank
Yea I’ve completely disabled warp on everything right now
Yea its clearly an issue and I made a post on Cloudflare forums but doesn’t seem to be gaining any traction
Are you using warp on a team/your own network
Cloudflare emailed a fix today regarding what ips to exclude
This worked for me thanks!! This has been broken for a while
An updated list: https://community.cloudflare.com/t/facetime-misbehaves-on-macos-w-warp-zero-trust/683172/14
Could you share a list of IP’s ? Same issue here.
Just did a complete reinstall on MacOS and still not working.
Check out the comment
