Localhost won't load even with firewall off
Trying to get Sunshine up and running. No matter what I do, I can’t get the localhost to load in my browser. I turned off my anti-virus and everything.
Are you sure the sunshine service is running?
Did you create a VPN tunnel anywhere?
I have firefox and linux downloading software tunneled through my VPN so it can’t access the internet without my VPN turned on. The rest of the computer runs fine without it though.
No. I installed and can’t get to the point of creating a sign in.
I think I have VPN settings through Avira, but I had everything turned off, with internet access, AFTER downloading and installing. I had to turn everything off DURING the installation. There’s supposed to be firewall rules instated during the installation, but they weren’t bypassing whatever I had going on. Haven’t identified exactly what that was.
3 questions:
  1. Are to trying to connect to localhost on the computer you installed sunshine on?
  2. Did you run sunshine after you installed it?
  3. Is sunshine running in the lower right hand corner (assuming windows) where the Internet connection, sound settings, etc. icons are?
First install and then nothing would happen once I started Sunshine. Would get this screen. Couldn’t create login. I un-installed and reinstalled twice. Same thing. Un-installed and reinstalled a third time with firewalls and anti-virus turned off during install. It now works.
