Can you buy letsvpn subscription using the Demo, while in china? My flight is tomorrow, and I am not sure if I should wait on buying until I’m there or before…
Use mullvadvpn. Let’s vpn didn’t work for me on my recent trip.
Buying a subscription to LetsVPN, whose director is Hong Lei, is easy in China. In contrast to other VPN services, CCP-approved platforms such as WeChat and Alipay allow you to access and pay for this VPN once you’re in the country. I wonder why?
Yeah it’s pretty easy, you could also get the 1 week subscription before your flight for a few dollars and see how well you like it when you get settled. If it’s Good then you can get more time. If not there’s many options.
Yes. You can buy LetsVPN using the free trial.
Let’s VPN has worked for the last month for me.
Just buy it before you arrive, saves the faff and any stress in case anything goes wrong.
Idk if its too late, but I do have some working Chinese VPN that charges only 77rmb for 3 months. I got it from a Chinese friend who use vpn to play games. Its however an apk file so its if you have android.
I have been using letsvpn since I got to China in August and had no issue. Use it on my computer, phone and iPad. I got it while in China cause the vpn I got before leaving stopped working once I got here.
I suggest some free vpn for 1st the get a paid when you are at chine for free android govpn and ios vpnify these currently working in china so check it out can save few buck for few day the get paid as you need…
Actually I don’t suggest using any VPNs cuz the GFW(Great Firewall) can easily detect the data flow encrypted in an actual vpn protocol and block it very quickly. Most VPNs don’t bother to improve its service against the GFW blocking. I recommend that you use other encrypted protocols to bypass the GFW. It means using specific proxy tools like clash, shadowsrocket, etc. They are all open-source apps safe to use. All you need to do is purchase a subscription from service providers that usually provide relay servers to bypass the GFW. All of your data flow is encrypted and secured before sent out and cannot be observed by the service providers or attackers. It’s not an actual VPN but works like one and better in China.
Idk, I just have the apk file
