L2TP IPSec VPN is pretty slow on MikroTik RBD52G-5HACD2HND-TC
Hi, My L2TP IPSec VPN is pretty slow, I got only 5 mbps down and about 3 mbps up when my internet connection is 600 mbps download and 150 upload (I mean where the VPN server is).
Tested it on Samsung Galaxy S7 connected to LTE+, without VPN connection I got 90 mbps down / 70 up, when VPN is connected, speed downgrade to maximum of 5 / 3 mbps.
My router is MikroTik RBD52G-5HACD2HND-TC with the latest updates installed.
Connection is stable but very slow. I believe I could get more/faster VPN speeds with this MT router. Didn’t try with the IPSec off, could it be a problem?
I attached some screens with my config below,
https://i.imgur.com/1TBMgpP.png
Thanks for any suggestions
Did you follow the following configuration?
https://www.reddit.com/r/mikrotik/comments/g3s7ev/is_there_a_recentmodern_l2tpipsec_tutorial_for/fntngot?utm_medium=android_app&utm_source=share&context=3
Try with IPSEC off. Also, when speedtesting is your CPU usage get high?
Xport your config and post here. Sanitize as needed.
Also, how are you doing your speedtest on and off vpn.
Did you check you ipsec encryption algorithms? According to https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Hardware_acceleration you should use AES-CBC+ SHA1/AES-CBC+SHA256/AES-CTR+ SHA1/AES-CTR+SHA256, or you won’t get hardware acceleration.
Run /ip ipsec installed-sa print after a successed connection, if hardware acceleration is enabled, there will be a “H” at the second column ( right of the line number ).
I just did a speedtest and got 15 mbit which is the best result so far (upload pretty slow) but have a look below, cpu usage was only at level of about 11%
https://i.imgur.com/gTnn9IL.png
speedtest
I am using speedtest app on my Galaxy S7 edge.
How do I test? Switch off WIFI > Connect to LTE+ > do a speedtest (get a result for about 90 mbps), close the speedtest app > connect to VPN and test again (and get a result for 10 mbps only).
Ok, well then its some kind of configuration issue.
Please know that routing to and from multiple networks, which will add latency, which will reduce bandwidth.
Essentially, with VPN, you’re routing from your phone > LTE network > into Home ISP network > out of Home ISP network > Speedtest.
Essentially, without VPN, you’re routing from your phone > LTE network > Speedtest.
While your home internet may be X speed, there’s no guarantee that your ISP and LTE networks have a direct connection, which will slow down speeds. This is common and why Verizon and Netflix were fighting each other for years.
