I am user of keep solid vpn and have a tmobile free netflix account? When my vpn is enabled and I try to access Netflix, it gives a error stating to the effect that I am not logging in in the region I am subscribed to. Any suggestions? Thanks.
Hello! If you need a VPN, check out the guide here!
Could it be that Netflix is currently limiting the service in the US to only one IP address per account? When you engage the VPN, it will show as if you’re connecting from a different IP address. This is just a theory as I don’t use a 3rd party VPN. It could also be the specific ip address tge von is assigning you is blacklisted by netflix.
Maybe open a free trial on another vp service and check if it works.
It’s because you’re using T-Mobile’s free Netflix account. It will only work in the US. If you need to use Netflix from another country, you can DM me, I’m from Pakistan and can offer it at a much cheaper cost, alongside Surfshark VPN.
