Issues with tunneled applications in safari since ios 18 update
Has anyone been experiencing issues with internal sites that go through the tunnel when using safari after the iOS 18 update? We have some internal sites that require auth and MFA and we started having issues after the update. Some error are related to too many redirects. Others are throwing an index out of bounds error with our MFA product. Makes me curious if anyone else is running into these issues, or something similar.
18.2 is resolved that MFA issue we have previously the same kind of issue like after approv from HUB The browser not able to accept the Auth and not moving the login process and also discussed with Omnissa they’re saying this is Apple issue but after updating 18.2 OS that issue resolved.
No just with ios18 and java script graphic rendering and switched to a chrome based browser for those. Sounds like an idp provider isssue , is it using Kerberos SSO ? Maybe it’s not reading the identity cert correct and then defaults to mfa for everything
Just as say this more issues with safari, tunnel vpn , and ios18 not starting one day and later works perfect
No issue with MFA on 18.2 and 18.3 beta. Need more information for your issue
This, unfortunately, did not resolve my issue.
I would think the idp if it didn’t work before the update. It’s been working for years. Apple always has to be different.
