Issues with Norton VPN. Now Missing Drivers
I’m really hoping somebody can help me.
So my Norton VPN stopped working. Instructions said to uninstall and reinstall the WAN MiniPort drivers through the Device Manager. I did that. Then it said to run a scan for hardware changes and follow the on-screen instructions to reinstall the drivers.
Problem is, that scan didn’t do anything. It didn’t detect that I’d removed them. Now they’re just gone, and for the life of me I can’t figure out how to reinstall them. I’ve looked all over Google trying to find a solution or to just re download them and no dice. Two different driver software update programs can’t detect them missing, either. But they’re not showing up in my Network Adapters, even when I show hidden devices. I’ve recently upgraded to Windows 11 from 10 if that makes a difference, but the VPN was working for a hot minute with Windows 11 just fine. Does anybody have any ideas at all? I’m at my wit’s end.
And yes, I’ve tried uninstalling and reinstalling Norton several times now. No dice.
Nordvpn is way better honestly, it’s a no hassle vpn with the simple matter of downloading the application and you have instant vpn. They had a special rate for 2 years a while back for 70% off, not sure they still do. But I highly recommend it.
Don’t use any Norton product, ever!
