Issue Norton VPN
Hello everyone, I have Norton antivirus and it includes a vpn, it happens that when I open the qbittorrent application the vpn is automatically disabled, no matter how much I try to activate it does not work, someone helps me.
Ok , you need to buy a real VPN which supports p2p.
Don’t use norton antivirus or VPN. Both suck
I like AirVPN. Reasonable price, does port forwarding which makes a huge difference and is easy to set up.
it dosen’t support p2p
Yeah, you’re gonna have to invest in a legitimate VPN because it doesn’t sound like you have one
Thanks for the advice
In all of my tests it doesn’t leak it when you bind it to the vpn network interface
Then I’ll look for one.
I use Nord VPN. A lot of people don’t care for it since it’s on the pricier end and doesn’t support port forwarding, but I enjoy it for its ease of use. There’s a lot out there depending on what your price range is
I had malwarebytes but my license expired a few weeks ago.
I started there too. Then went to Express and it was giving me issues with a tracker. Switched to Nord and it’s been good so far
malwarebytes got a VPN , which uses Mullvads servers ( Btw firefox VPN is also Mullvads servers )
Lamento la confusión, leí que dijiste Norton
But are you using it?
i got access to over 16 vpn still ( had 25+ at my testing times ) atm i use privately windscribe.
malwarebytes is prob decent
Malwarebytes VPN is just Mullvad with another Middle man ( malwarebytes ) between.
why use Norton
ask op , i dont use Norton , nor recommend it.
Yep , you can also clearly see an Quality degradation performance wise on the norton bought products like Avast and AVG / avira , Avast lost its Modularity in its newest versions as an example and got heavier.
