The only issue with Proton is the port forwards chabges each login so important to ensure you’re comfortable wirh that and how to work with it. Air VPN you get 5 but a bit less speed.
proton works good! Just make sure that you use the Beta Linux app, since it has wireguard. (Wireguard is better than OpenVPN for speed most of the time).
I have proton and qbittorrent, do I need to do anything else than enable port forwarding in Proton and copy the port to qBittorrent? Is that what you mean by ”binding”? Cheers
From what I was able to piece, you need to put the right network adapter
Tools > Preference > Advanced > Network Interface
For me, I use “Surfshark_wg”. I’m unsure how proton is called.
I plan to create a virtual machine just for torrenting with my VPN’s network adaptor :3 so I’m sure if the connection get down, my VM would simply lose internet
Thank you, I will try to bookmark this. Since I get asked how to deal with the Proton ports a lot and I have no clue since I have enduring port forwards.
I would highly recommend getting a good VPN such as Proton VPN, most free VPNs don’t allow torrenting through them, they’re more for general web surfing/anonymity. McAfee is garbage and I’d avoid any of their software all together.
As for binding qBittorrent to the VPN; what it essentially does is only allows torrenting whilst the VPN is connected so in the case of your VPN losing connection it won’t allow anymore traffic though and exposing your real IP address, obviously this can lead to letters from your ISP for downloading copyrighted material depending on the content and country.
Binding is the only safe way to torrent, you will see people talk about kill switches but it’s not 100% safe and best off avoiding kill switches in the case of torrenting.
