Is it possible to set Windscribe to Windows's integrated VPN system?
It is much faster to connect through Windows’s VPN setting on the action center. So, I was wondering if it is possible to set Windscribe through it as well
https://windscribe.com/guides/windows
What are the benefits of going this route instead of the typical app installation?
Thank you very much. So, I believe it is only available for pro accounts? Still good know
Not much. Mostly convenience because Windows’s VPN toggle can be quickly enabled through quick settings and also lets you know when you are connected to the VPN on the WiFi icon. I wish both the quick settings page and VPN apps could be accessible by third parties as well like on phones but until Windows decides to do that, only Windows itself has access to these
Don’t know why you got downvoted, it’s true … Say it literally in the first part.
Step 1
Get IKEv2 profile and credentials (requires a pro account).
Thanks for confirming.
