Is it possible to set a VPN to connect from a specific address?
Ok, here me out here,
Let’s say someone has to clock in/out for work and the app is geotagged but you are a bit late for work…
Is is possible to set a VPN, connecting you to that exact place enabling you to clock in/out of your work space from anywhere ?\
Asking for a friend…
Reset the counter everyone.
you are prob looking for spoof locations apps for android
Depends what you mean by geotagged. If it’s IP based, you could set up a private VPN server in the location you’re supposed to be and connect to it from anywhere.
If the app is on a mobile phone and uses any type of mobile radio or GPS location data, then the VPN will not help you at all.
Read this: https://thewirednomad.com/vpn
Interesting :face_with_monocle: thank you :folded_hands:t2:!
