Is it possible to get Kaspersky in the us by buying it .ca? (or by using a vpn?)
is it possible to get Kaspersky in the us by buying it .ca? (or by using a vpn?)
Kaspersky activation codes bought pre-ban through Newegg and Amazon have kept working for a number of people in the US.
I have to use a VPN to update signatures on Android, but not on desktop. On desktop it’s possible to change the server used to download the updates without needing a VPN.
The Canadian Newegg.ca storefront sells Kaspersky digital codes. You’d probably need to use a VPN to activate it.
I haven’t seen anyone post about trying it yet, but if Kaspersky still works once I’ve used my current stash of activation codes, that’s what I’ll be doing.
I imagine Kaspersky will happily sell you their anti-virus anywhere in the world. I don’t believe they are allowed to send you a single update in the USA, so it might not be very useful.
