Hello, I tried to connect to VPN but it was loading very long to connect so I just turned it off, but after I turned it off my internet stopped working. I didn’t think it was a such a problem so I restarted my PC. But even after I restarted my PC the internet is not working, it shows me “No internet, secured” or sometimes “Connected, secured” but it’s still not working. Any help on fixing that?
Does the vpn have a kill switch on? If so, disable it and the internet should work.
what VPN software did you install? what VPN service?
start with Windows > Settings > Network & Internet > Network reset is a link at the bottom
It doesn’t have a kill switch, but it has a firewall if that helps?
that didn’t seem to work ;( thanks for helping anyways
I used Windscribe. I did everything now I have to wait 5 minutes before the reset
Can you turn the firewall off?
Or can you uninstall it to ensure it is just the app causing issues?
That worked, thanks alot I just had uninstall all the VPNs I had
