If you are in EU and experiencing lag, try ultra surf
McAfee and many antivirus softwares also reports Ultrasurf as a backdoor trojan. wiki
I’m not tech savy enough to make any comment on how accurate this is, just figured I’d throw that out there, in case anyone is worried about being anonymous and what not.
Tried ultrasurf, ended up on http://community.justin.tv/mediawiki/index.php/Suspended_accounts
“use ultrasurf” how? to do what exactly? why did you link to the post instead of just explaining?
So with the .exe running, I can just F5 the stream page in my default browser? Because even though I tell UltraSurf to not use IE, only IE ever starts when pushing the Home button.
doesn’t work here, can’t even connect to any site with the program running…
the program doesnt start for me
Had no effect for me, still lagging.
sweet, worked for me in the UK! Thanks!
It was lagging as hell.
Now it’s perfect.
You saved evening for me.
I am a long time on Reddit, but never had an account.
Now I have. Registered to say thank you
If I untick the option for using IE, it seems like it doesn’t do anything with any of the browsers. Unless I tick the option to open IE on start it doesn’t work. And when I do open the program and it opens IE the streams doesn’t work, they don’t even show up. It’s just the grey background from TL. This program seems quite worthless unless I’m doing something wrong.
This worked perfectly for me and I’m based in the UK. Excellent suggestion!
install then lag just will disapear im amazed how easy that was and how well it worked
With UltraSurf, your are getting the non-laggy american (!) stream
That is all and it works
Should work with any other fast proxy
This is golden. Too bad we have to end up resorting to proxying to view a tournament in a viewable quality.
My stream is currently going, but if I try to re-access it in a new tab or try to open some of the VODs in the IE window I have open, I get sent to the “Suspended accounts” page.
So, they are cracking down on this - I’m just making sure to not refresh the window I currently have open with the stream going at 720p+.
Thanks Twitch TV, for blocking the one way to watch your shitty streams without lag from Europe! Douchebags.
Just downloaded it. It is working perfectly, I can actually watch the stream now.
I have to watch the stream at Twitch however. Teevox gives an error message when using it “This application is rate limited: Failed to make rate limit request”.
Something really fucking fishy is going on here. I’m thinking spam accounts have came here en masse. Including OP. The site is really shady.
Thank you, no lag anymore! Good find!
how the fuck does this even work? i’m using it now and i’m somewhat amazed at how much smoother the stream runs now.
i’m guessing it gives me a better routing to justin.tv’s servers?
