I want to double VPN (multi hopping ) with NordVPN in docker
Hello, I want to do double VPN with NordVPN as likePhone>VPS>NordVPN
I have already made connection
VPS>PhoneVPS>NAS in my home
so currently I can connect to NAS through VPS.But I want to connect to the internet with NordVPN instead of VPS’s Global IP address.
Now my VPN network created by Docker-compose
version: "3.8"
services:
  adguardhome:
    image: adguard/adguardhome
    container_name: adguardhome
    restart: unless-stopped
    ports:
# I open the ports it required by adguardhome
    networks:
      proxy:
      wg-net:
        ipv4_address: 10.2.0.100
    environment:
      - PUID=xxxx
      - PGID=xxxx
    labels:
      # adguard dashboard
      - "traefik.enable=true"
      - "traefik.http.routers.adguard.rule=Host(`xxx.xxxx.xxx`)"
      - "traefik.http.routers.adguard.entrypoints=websecure"
      - "traefik.http.routers.adguard.tls=true"
      - "traefik.http.routers.adguard.tls.certresolver=myresolver"
      - "traefik.http.services.adguard.loadbalancer.server.port=80"
      # Watchtower Update
      - "com.centurylinklabs.watchtower.enable=true"
    volumes:
      - ./workdir:/opt/adguardhome/work
      - ./confdir:/opt/adguardhome/conf
  wg-easy:
    image: weejewel/wg-easy
    container_name: wg-easy
    volumes:
      - .:/etc/wireguard
    cap_add:
      - NET_ADMIN
      - SYS_MODULE
    environment:
      # ?? Required:
      # Change this to your host's public address
      - WG_HOST=xxx.xxxx.xxx
      # Optional:
      - PASSWORD=xxxxxxxxxx
      - WG_PORT=${EXTERNAL_WG_PORT}
      - WG_DEFAULT_DNS=	10.2.0.100
    labels:
      # Watchtower Update
    ports:
      - "${EXTERNAL_WG_PORT}:51820/udp"
      - "51821:51821/tcp"
    dns:
      - 10.2.0.100 # Points to AGH
    networks:
      wg-net:
        ipv4_address: 10.2.0.3
    sysctls:
      - net.ipv4.ip_forward=1
      - net.ipv4.conf.all.src_valid_mark=1
networks:
      wg-net:
        ipam:
          config:
            - subnet: 10.2.0.0/24
      proxy:
        external: true
Then I add nordVPN container
version: "3.8"
services:
  adguardhome:
    ports:
#as I wrote above
    networks:
      proxy:
      wg-net:
    environment:
      - PUID=xxxx
      - PGID=xxxx
    labels:
      # adguard dashboard
      - "traefik.http.routers.adguard.rule=Host(`xxxx.xxxx.xxx`)"
      # Watchtower Update
    volumes:
  nordvpn:
    image: ghcr.io/bubuntux/nordvpn
    container_name: nordvpn
    cap_add:
      - NET_ADMIN               # Required
      - SYS_MODULE
    ports:
      - ${EXTERNAL_WG_PORT}:51820/udp
      - 51821:51821/tcp
    environment:                # Review https://github.com/bubuntux/nordvpn#environment-variables
      - USER=${NORDUSR}          # Required
      - PASS=${NORDPW}            # Required
      - CONNECT=${COUNTRY}
      - TECHNOLOGY=NordLynx
      - NETWORK=10.2.0.0/24  # So it can be accessed within the local network
      - PORTS=${EXTERNAL_WG_PORT};${EXTERNAL_SOCKS5_PORT};51820;51821
      - FIREWALL=Disable
      - KILLSWITCH=Disable
      - CYBER_SEC=Disable
      - DNS=${NV_DNS}
    sysctls:
      - net.ipv4.conf.eth0.rp_filter=2
    devices:
      - /dev/net/tun
    networks:
        wg-net:
          ipv4_address: 10.2.0.2
  wg-easy:
    volumes:
      - .:/etc/wireguard
    cap_add:
      - NET_ADMIN
      - SYS_MODULE
    environment:
      # ?? Required:
      - WG_HOST=xxx.xxxx.xxxx
      # Optional:
      - PASSWORD=1DifW6C4yeLxN1gi
      - WG_POST_UP=ip rule add from 10.2.0.2 table 128; ip route add table 128 to 10.2.0.0/24 dev eth0; ip route add table 128 default via 10.2.0.1; iptables -t nat -A POSTROUTING -s 10.8.0.0/24 -o eth0 -j MASQUERADE; iptables -A INPUT -p udp -m udp --dport 51820 -j ACCEPT; iptables -A FORWARD -i wg0 -j ACCEPT; iptables -A FORWARD -o wg0 -j ACCEPT;
      - WG_POST_DOWN=ip rule del from 10.2.0.2 table 128; ip route del table 128 to 10.2.0.0/24 dev eth0; ip route del table 128 default via 10.2.0.1
    labels:
      # Watchtower Update
    sysctls:
    network_mode: service:nordvpn
    depends_on:
      - nordvpn
networks:
      wg-net:
        ipam:
          config:
      proxy:
        external: true
but mostly it does not work. (I don’t know why it worked 2times but after docker compose down && docker compose up -d, it dies connection.)I tried to ping from NAS to VPS or Phone, but neither to work. Maybe I need to change some parameters on WG_POST_UP or WG_POST_DOWN but I am not sure. What should I do?
Edit: I found I can connect the internet through nordvpn that I changed - NETWORK=10.2.0.0/24 # So it can be accessed within the local network to - NETWORK=IP address of my global address of home # So it can be accessed within the local network I don’t know why it works even I can connect from Cellular network and I am worried about when the global IP changed of my house.
“What should I do?”
Start by finding the last interface the packet is captured on. source/destination ips and ports of said packets are also important.
Finding the last interface tells you where it gets drop/rejected rather than NATted onwards, the ips/port tells you if the packets are NATted properly. This all narrows down the point of failure so that rules can be adjusted accordingly.
