My PIA VPN wont connect to any server through OpenVPN nor Wire guard . With wire guard it does connect to the server but it doesn’t give me VPN Ip and after a few seconds it disconnects . I have this issue with my home fiber internet connection and as for my mobile cellular network PIA works fine with it .
I’ve reached online support 4 days ago and they said they will forward this matter to the engineers and i haven’t heard anything from you since then .
I’ve tried some other free VPN s and they all connects and works fine with my fiber connection . i think maybe PIA should have add some more VPN protocols ?
I have experienced exactly the same. Places where PIA does not work, Windscribe IKEV2 and ProtonVPN in stealth mode works. I agree, PIA needs to update.
I do have one work around that is a pita but may work, connect to pia while on mobile, then connect to wifi. That works for me at my gym, but not everywhere.
I experienced this issue in the past and it was tied to our provider (work) blocking VPN connections. If i connected to cellular it would work fine. If I tethered my laptop to my phone, it would connect fine. If I connected either my phone or laptop to the wifi network, PIA wouldn’t connect, or would disconnect if it was already connected via cellular.
Thanks for this tip! I was having issues with PIA cutting my speeds by 95% - 97% (28-47 Mbps on VPN vs. 940 Mbps off VPN), and turning on Shadowsocks is the only thing that has helped. With Shadowsocks on I am getting 410-490 Mbps, which I can live with to have some protection.
Yes . But i could work around it according to MrTooToo method he said above : connect to pia while on mobile, then connect to wifi. That works for me at my gym, but not everywhere
This worked for me on wire guard . I connect to PIA wire guard with my mobile network and then on turn on wifi and it still connects . It doesnt connect directly with Wifi.
On the other hand, do you have shadowsocks for mobile?
