How to Share Internet With NordVPN from MacOS to other device?
I am trying to share the connection from my macOS to my Samsung TV. I tried the internet sharing option, but I only had ethernet and NordLynx, when I select ethernet I got a hotspot but without vpn protocol applied on it, and if I select NordLynx then the hotspot will not shows up at all.
I even tried setting up IKEv2 but it doesn’t shows up on internet sharing menu and NordVPN doesn’t support IPsec even if they still say that “without shame” on their website.
Any idea? And btw i can’t setup router vpn cause for whatever reason NordVPN doesn’t support Fritzbox!
Edit: for anyone visiting the post later here is how it worked.
First, you have to build the config file for wireguard, as you can find in the comments below, which requires Privetkey, publickey and endpoint (search YouTube on how to find them on mac or linux)
Second go to Fritzbox settings and under Wireguard VPN add new connection and make sure to select the second option and after that select yes and upload the config file you built already.
Follow this tutorial https://avm.de/service/vpn/fritzbox-ueber-wireguard-mit-vpn-anbieter-verbinden/
Seems like the OS your router hosts does support WiteGuard, Meshnet is essentially WiteGuard, and it’s easy for me to believe if you follow a guide for something like OpenVPN/Nord you’ll probably be able to do the same with the WiteGuard client potentially available on your router. Some references I found here, if you don’t already know pfSense is just an open source firewall and with a bit of research you’ll find your answers
https://www.reddit.com/r/WireGuard/comments/pzvq08/wireguard_with_nordvpn/
https://www.reddit.com/r/PFSENSE/comments/m0989o/nordvpn_wireguard_setup_works/
I don’t own an iPhone but it may be possible to point the hotspot DNS server to the Nord IP on your app, this should allow anything connected to the hotspot to utilize the VPN as well.
Wouldn’t surprise me if Apple doesn’t like that kind of thing but worth checking out
The DNS servers for something like WireGuard and OpenVPN are different than what you’d want to set the hotspots DNS for, that will be the local IP of the Nordlynx virtual NIC/adapter
Sorry, but you’re off on a few things here.
Meshnet is not essentially wireguard, it’s a completely separate thing.
Wireguard is a type of protocol, like OpenVPN. Nordlynx is what Nord calls Wireguard.
OP is asking how to share a VPN connection from a Mac, not an iPhone. I think you misunderstood the post.
OP, if you want to use your router with Nord, it needs to support “vpn client” not “vpn server,” which is probably what you’re seeing on your Fritzbox. VPN server would just allow you to connect to your home network while you’re away from home.
VPN client would let your devices connect to Nord via the router. I don’t think it’s common for ISP provided routers like Fritzbox to support vpn client so you’d probably have to buy a new router.
I’ve never tried to share a VPN from my MacBook, but you should try just googling “how to share VPN from mac” and follow one of the guides, if you haven’t already done so. If you don’t find anything good, add the word “reddit” to the search. Otherwise, maybe someone else here will have some experience with this.
Thank you, I was pressed for time and figured Id throw something out there, not that I’m a liable source of info regarding anything Apple. I have had WireGuard recognize/share my Nord Meshnet connections in the past but that’s on Linux and done by mistake as I was trying to set up WiteGuard for the server lol.
Anyway man, thanks for catching all that and steering OP in a more accurate direction
Thanks for the info, actually I did already that and came empty handed. No tutorial is working cause many of them just ( copy paste from clickbait articles.
However to add to your point about wireguard, my router isn’t an IPS router AVMAVM ( Fritzbox) is one of the biggest routers manufacture hier in EU and has nothing to do with any IPS. The router support wiregaurd and I found this “ GitHub - sfiorini/NordVPN-Wireguard: A bash scripts that generates Wireguard configuration file for a NordVPN connection. ” so I am thinking if I can redirect the router to connect through wireguard on my mac. What you think ?
Ahh that’s a bummer. Sorry if I got some of the info on Fritzbox wrong, I spend a lot of time in Germany and set up the router for my relatives, which was a Fritzbox delivered from Vodafone. While it may not be exactly an ISP router, it will still be more limited in terms of VPN than a privately purchased router and that’s why a lot of ISPs use it.
I don’t speak German, but when I translate these VPN related topics, they are saying you can connect to your home network while away from home. This is a “vpn server” function, and what you need is “vpn client.”
I live in another EU country, but I had to purchase my own router to use “vpn client” which is the feature you want.
For some reason, I am getting a 404 error on the page you linked. Maybe I’m misunderstanding, but I think your question at the end there is not possible.
Thanks again bro, the AVM isn’t the problem as far as I can see, the problem is NordVPN, cause it doesn’t support IPsec anymore! And even doesn’t support Fritzbox for now and they are workingon solution (this is what they say on their website since forever).
Back to the wireguard point, I did find this option which translated to English “Set up a WireGuard® connection between two FRITZ!Box networks, this FRITZ!Box and a VPN provider, this FRITZ!Box and a WireGuard® server, or other special WireGuard® connections." What I can understand from this that I can made all connection to router go through the wireguard vpn first. I did set it up correctly and it was on, but on my end devices nothing happened, as I am not using vpn at all.
After many days of trying to find a way to do that and many problems found, I can say that I was wrong by buying 2 years NordVPN subscription, and I will search for another, better VPN that support IPsec at least.
No problem, sucks that I couldn’t be of much help.
You said your end goal was to get a VPN connection on your Samsung TV right? If you ever decide to buy a new router, check out ones that have VPN fusion from Asus.
I bought one a few months ago and can’t recommend it enough.
VPN fusion works with both OpenVPN and Wireguard and I can confirm it works 100% with Nord.
With VPN fusion you can do something like this:
TV connected to Nord UK server
Laptop connected to Nord US server
Phone connected to Nord Germany server
All other devices connected to regular wifi.
You set up everything on the router admin panel and choose which device connects to which server. It only took a few minutes to get it running.
If it’s something you want to look into, let me know and I can link you to the list of routers with that feature since it was kind of annoying to find so I bookmarked it.
Thanks man, Asus fusion seems pretty useful feature, however for now I can’t easily sell my router (2 month old) and buy a new one for this, it would be money lose in that case.
What I can’t understand that I did everything right on the Wireguard thing and I could even use the .confg file correctly on the Wireguard app, but still no luck on the router itself. If it is shows that the wireguard profile is on.
If you look on this page https://avm.de/service/vpn/fritzbox-ueber-wireguard-mit-vpn-anbieter-verbinden/ it is in german but maybe you can translate it using browser, you can see it is exactly what I am looking for and I did all steps correctly but no luck!
It works https://www.reddit.com/r/nordvpn/comments/13uf3mp/how_to_share_internet_with_nordvpn_from_macos_to/jm4d282/?utm_source=share&utm_medium=ios_app&utm_name=ioscss&utm_content=1&utm_term=1&context=3
I added the file and it works now on my computer, the question is, is my private key related to the Mac, or related to may Nordvpn account ?
Ans should I change the allowed IPs to the one for my Samsung Tv on the network?
Thanks, actually I am using it on my Mac, I have two working tunnel profile for Wireguard I built using the script you mentioned above and both are working flow less on my mac. The problem is when I do add them to the router, it don’t work, I think nordvpn have problem with Fritzbox that’s way they don’t support them. I read something about pfsense but it looks so much complicated to my skills in that field.
Hey, your submission was automatically removed because your account does not meet our karma standards. Accounts must have a minimum of 100 combined karma to post in this subreddit. This rule is meant to improve the quality of posts being submitted while mitigating abuse from troll accounts.
Not yet but I will contact them tomorrow. The thing is, the router accept the configuration file and I get server on, but still if connect to the router wifi, nothing happens and no von protocol applies on my TV or mobile device.
You wouldn’t believe it, but it’s actually working now! All I had to do is waiting about 10 min, I did use the same confg file I built from the morning. Don’t know why but now it works, even though NordVPN support said it is NOT possible. Which is so sad that the support team doesn’t know about their product enough.
Thanks a lot for help bro :+1:t2:
Hi there, I’m trying to configure a config file myself, could you tell me how you got the necessary credentials? I’m struggling especially with the private key and public key.
That would be of great help, thank you!
So the config itself is working when I used in in the WireGuard Client. It’s working great everywhere except on my FritzBox. I was hoping that waiting a couple of minutes would solve the issue like it did for you, but it didn’t. I then realised, that the connection won’t even work on my wireguard client anymore while in my home network. As soon as I use a different Wi-Fi it’s working. Have you encountered this issue by any chance?
Have you followed this https://avm.de/service/vpn/fritzbox-ueber-wireguard-mit-vpn-anbieter-verbinden/ ?
I did, without any luck. I think it’s got to be something about ports or the IP being blocked, I’ll ask for help on a different sub since this seems to be a routing problem of some sorts. Thanks for you help!
