How to setup a key for System Settings to launch VPN
Can someone please help me figure out how to setup a key that launches Windows System Settings → VPN Settings? Even better if it could select and connect to the right VPN in the list. Thank you!
It’s been a while since I’ve tried this, but you should be able to add the VPN connection to a Shortcut and launch the shortcut with the System > Open action on the Stream Deck+.
Once you’ve setup the VPN, Press Windows Key + R, type ncpa.cpl and press ok. Find the VPN, right click it and Create Shortcut. Then you should be able to add the Shortcut to the Stream Deck with the Open option.
If that doesn’t work as expected you should be able to setup a Powershell script to do it.
