i want setup VPN only 1 session per user, but when try with same user to login for 2nd session
forti client vpn always pop up for confirmation to disable 1st user
already check
limit user to one ssl conmection at time on ssl vpn portal
set 1 limit concurrent user on ssl vpn realms
What is it you want the behavior to be, if a user is connected to a tunnel and then tries to connect to another tunnel?
Because I don’t think you can get around the notification if they try to connect to multiple tunnels.
i want only 1 session per user
i want keep only 1st session vpn and disable the notification
so if they share to another person (user & vpn password)
2nd person can’t connected to vpn
Yeah, that’s my point — you apply it to the user - not the concurrent sessions per realm.
I don’t know of a way to disable the notification.
But the second part should work as you want.
