in my country the ISP blocks some sites like porn or something political. so i use hotspot shield add-on on chrome to access these sites. i can enable what blocked site to use this addon so it doesn’t affect the others. but ublock can’t block ads in most case, there are a lot of pop-up, so what can i do, thanks in advance and sorry if my english is bad.
Simple enough, just dont use hotspot shield. I personally suggest using open vpn. It’s free and has many servers in many different regions.
I tried some free vpn before and the experience is usually bad, high ping, sometime fail to load page and down/upload speed are unstable, but i will try this one. Thanks.
No problem. Just make sure you chose a server close to you for an optimal experience. Also I have noticed that some of the servers don’t work properly so don’t give up if the first server you use doesn’t work right.
