I have tried using VPN (I use ExpressVPN) and removing sim card, but still getting to “No connection to internet” error. Has anyone tried anything that could work? Thank you!
Install opera, then Google how to turn on vpn (free) with opera, select the region you wanna browse TikTok from, then done ![]()
You don’t need a VPN you need a foreign SIM card. Try to get an eSIM and then turn off your HK /sim
I can do it with an iPad (or devices without a SIM card) and VPN
- Buy a flight ticket,
- Take the flight,
- Use TikTok
- Come back.
Take out SIM card and use vpn
They tell me Reddit is brain rot, but TikTok is CCP-controlled brain rot at best, the pinnacle of human stupidity and echo chambers at worst. Do not install TikTok.
Hi! I managed to access the web version with Opera, but that doesn’t allow me to post videos. Do you know any workarounds for the app version? Thanks!
I did it and it worked but today I can’t access it what do I do
Thats right, instead go out and find a patch of grass, and touch it
Out of curiosity, why do you need to use TikTok and refuse to use the local / Chinese version of it (Douyin)? To be honest you gonna need legit vpn plus another region of store app in order to use TikTok and it probably is not worth it for normal user.
