Been googling around for ages for more specific instructions but coming up short with the know-how.
Currently I have a Google WiFI setup at home (so no router firmware options here) and a QNAP NAS running dockers (Delugevpn, Sonarr, Radarr, Jackett). As Deluge is running through OpenVPN, I can’t access it’s WebUI when I’m considered outside the LAN, which makes sense. Currently, I remotely wake up my Desktop, remote desktop into it and then proceed from there.
I don’t want to have to keep doing that, so would I go about using a computer outside the LAN and make it part of the LAN? All I’ve garnered was that it has something to with putting my LAN behind a VPN and then I would have to access/authenticate through this VPN to become part of the LAN at home? Do I accomplish this through the QNAP NAS?
Good luck with it! I’ve set up several OpenVPN servers for this purpose and can connect to them all day long, but I’ve never found a good write-up on how to make a client’s traffic go through it to connect to anything at the home network. Maybe your google-fu is better than mine.
if you want it really secure, setup server certificates & encryption keys to secure the virtual network you will have… this will merge the server & client networks together into one and you can share/access all devices in both networks…
DNS is required because one network needs to know how to get to the other network… DNS servers are the phone books of the internet… without them, one network can’t find the other…
for example: being a huge fan of pfSense, I have pfSense routers at home and work… also have a travel unit I take on trips… one is server, the other is client… pfSense has ability to use keys and encryption to your hearts content… once its all setup, I have full access to/from either location to the other location… accessing files, printers, servers, etc… just like being in both places at once…
Reddit has become the new search engine. Ask a question and it will be answered, tailored to your specific question, because you are special, and nobody has ever asked that same question before.
you don’t have to buy a domain, but if you do, domains.google.com . plenty of dynamic dns forwarders out there. – if your IP doesn’t change often you can use something like chrome remote desktop to connect to get the IP if it changes.
It creates a virtual network adapter and runs a service for direct connection between the machines. There’s only a connection to their servers to initiate the direct links, and if you wanted to you could go through some more complex configuration to entirely bypass the initial connection.
Any tips ? "Per the official OpenVPN documentation, you should place your CA on a standalone machine that’s dedicated to importing and signing certificate requests. "
How i can configure something for this stand alone PC ?
I actually have only one machine 24h\7D with a VM running PI-Hole on Diet Pie. But thinking putting Pi-hole or VPN on an RPI3 …
