How can I use multiple devices on a network?
Is there a way to utilize a guest Wi-Fi and VPN or something similar? I also have a Raspberry Pi here. How do you go about it?
  1. VPN is against Honeygain ToS. not that they don’t allow it, it’s just useless for both you and Honeygain because it masks your internet usage, thus making honeygain not able to use your data (if I’m not mistaken)
  2. The device limit is made for a good reason, because no matter how many devices you use on your network, they are all gonna earn as same as one device.
Honeygain used to allow 2 devices per IP, what I like to do is install it on other people’s system and hide the icon. :wink:
You can only use one device per public ip. VPN’s usually provide database ip addresses which are not supported by honeygain. If you were to just buy a residential vpn just for honeygain it wouldn’t be economical.
