Hi, after looking on couple of guides, I tried to create a VPN in AWS.
Currently, in doesn’t work. Each time the message is a little different, and I’m not sure what I did wrong, how can I troubleshoot the issue?
I start on a new region in order not to damage the existing configuration in the main region I use.
I created certificate with easyrsa aws guide
then I created client VPN endpoint base on base VPC that AWS create by default.
Added associated authorization rules (AWS default) and security groups (AWS default)
after a couple of minutes, the state become available, and I tried to use AWS VPN client.
It doesn’t create logs that I can check, and the message is not very helpful.
I saw a couple of guide how to create VPN on AWS like this, and they all pretty much do the same, no sure what I missed.
Thanks for help
