Help With Softether VPN - Access Server Services
hey guys. I’m trying to setup a vpn with softether vpn server on a DigitalOcean droplet.
The server is running and I can connect to it with my Mac and Phone. Now I want to access services running on the droplet via the VPN.
If I understand the softether documentation correctly, the easiest way is to run the softether client on the server and connect it locally (via localhost). The client is connected but get no ip from the DHCP server like the Mac or Phone.
Any suggestions to get it working?
If I understand correctly you want to setup SoftEther VPN server or client?
Basically I want setup Softether VPN Server with access to local services via the VPN connection.
Everything’s work fine except the access to local services.
