upon checking logs the following TLS handshake error is present. but I cannot work out what incorrect configuration there might be:
Jul 30 08:43:22 unknown daemon.err openvpn[28533]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jul 30 08:43:22 unknown daemon.err openvpn[28533]: TLS Error: TLS handshake failed
Jul 30 08:43:22 unknown daemon.notice openvpn[28533]: SIGUSR1[soft,tls-error] received, process restarting
Jul 30 08:43:22 unknown daemon.notice openvpn[28533]: Restart pause, 5 second(s)
Jul 30 08:43:27 unknown daemon.warn openvpn[28533]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Jul 30 08:43:27 unknown daemon.warn openvpn[28533]: WARNING: No server certificate verification method has been enabled. See
http://openvpn.net/howto.html#mitm
for more info.
Jul 30 08:43:27 unknown daemon.warn openvpn[28533]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jul 30 08:43:27 unknown daemon.notice openvpn[28533]: TCP/UDP: Preserving recently used remote address: [AF_INET]
5.226.139.225:1194
Jul 30 08:43:27 unknown daemon.notice openvpn[28533]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jul 30 08:43:27 unknown daemon.notice openvpn[28533]: UDP link local: (not bound)
Jul 30 08:43:27 unknown daemon.notice openvpn[28533]: UDP link remote: [AF_INET]
5.226.139.225:1194
Jul 30 08:44:27 unknown daemon.err openvpn[28533]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Jul 30 08:44:27 unknown daemon.err openvpn[28533]: TLS Error: TLS handshake failed
Jul 30 08:44:27 unknown daemon.notice openvpn[28533]: SIGUSR1[soft,tls-error] received, process restarting
Jul 30 08:44:27 unknown daemon.notice openvpn[28533]: Restart pause, 5 second(s)
Jul 30 08:44:32 unknown daemon.warn openvpn[28533]: WARNING: --ping should normally be used with --ping-restart or --ping-exit
Jul 30 08:44:32 unknown daemon.warn openvpn[28533]: WARNING: No server certificate verification method has been enabled. See
for more info.
Jul 30 08:44:32 unknown daemon.warn openvpn[28533]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jul 30 08:44:32 unknown daemon.notice openvpn[28533]: TCP/UDP: Preserving recently used remote address: [AF_INET]
185.125.207.177:1194
Jul 30 08:44:32 unknown daemon.notice openvpn[28533]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jul 30 08:44:32 unknown daemon.notice openvpn[28533]: UDP link local: (not bound)
Jul 30 08:44:32 unknown daemon.notice openvpn[28533]: UDP link remote: [AF_INET]
Jul 30 08:44:53 unknown daemon.err openvpn[28533]: event_wait : Interrupted system call (code=4)
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: OpenVPN STATISTICS
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: Updated,Thu Jul 30 08:44:53 2020
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: TUN/TAP read bytes,0
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: TUN/TAP write bytes,0
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: TCP/UDP read bytes,0
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: TCP/UDP write bytes,168
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: Auth read bytes,0
Jul 30 08:44:53 unknown daemon.notice openvpn[28533]: END
