Hey, si I’m using Tunnelbear, it says I’m connected to NZ, but when I lanunch the game it says that it IS restricted in my country (not 1st launch)
What could be the cause?
Keep trying, and use the speedtest app to check which server you’re currently connected to. Due to high demand to the NZ server, Tunnelbear has trouble actually connecting you sometimes even though it says you’re connected.
I’m not 100% sure, just guessing off of my experience, but I think tunnelbears NZ server is having big issues. It used to work just fine for me but a few days after tcgp launched it started having some connection issues until it seemed to be totally broken short after.
Personally I just accepted defeat and bought a month of nord. Had absolutely no luck with NZ tunnelbear after the issues started.
TB never worked for me Day 1. Just use Nord VPN.
Thx I understand, kept trying for a long time sadly but it’s working now
They confirmed it. Because everyone is connecting to NZ right now, its having tons of issues.
